[GRASS-dev] Re: [GRASS GIS] #1262: r.proj broken in all dev versions
trac at osgeo.org
Wed Jan 26 21:43:50 EST 2011
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.1
Component: Raster | Version: unspecified
Keywords: r.proj, reprojection | Platform: MacOSX
Cpu: OSX/Intel |
Comment(by cmbarton):
I just did an updated from the svn trunk (after a make distclean). This
has changed the results and error, but has not corrected the problem. Just
to be sure that there is nothing weird with the map, here is what I did. I
opened the NC_spm_07 dataset and set the region to match the
elev_state_500m dem. Then I tried to reproject into the state plane region
the 1 arc second dem from the nc_ll location. I set debug=5 and here is
the result.
GRASS 7.0.svn (nc_spm_07):~ > g.gisenv set="DEBUG=5"
GRASS 7.0.svn (nc_spm_07):~ > r.proj input=elev_ned_1arcsec location=nc_ll
mapset=PERMANENT output=elev_ned_1arcsec
D1/5: G_find_raster(): name=elev_ned_1arcsec mapset=user1
D2/5: G__read_Cell_head
D2/5: G__read_Cell_head_array
D3/5: region item: proj: 99
D3/5: region item: zone: 0
D3/5: region item: north: 318500
D3/5: region item: south: -16000
D3/5: region item: east: 963000
D3/5: region item: west: 124000
D3/5: region item: cols: 1678
D3/5: region item: rows: 669
D3/5: region item: e-w resol: 500
D3/5: region item: n-s resol: 500
D3/5: region item: top: 1
D3/5: region item: bottom: 0
D3/5: region item: cols3: 1678
D3/5: region item: rows3: 669
D3/5: region item: depths: 1
D3/5: region item: e-w resol3: 500
D3/5: region item: n-s resol3: 500
D3/5: region item: t-b resol: 1
D1/5: G_find_raster(): name=elev_ned_1arcsec mapset=PERMANENT
D1/5: G_find_raster2(): name=elev_ned_1arcsec mapset=PERMANENT
D5/5: color buf = [0% yellow]
D5/5: color buf = [20% green]
D5/5: color buf = [40% cyan]
D5/5: color buf = [60% blue]
D5/5: color buf = [80% magenta]
D5/5: color buf = [100% red]
Input Projection Parameters: +proj=longlat +a=6378137 +rf=298.257223563
+no_defs
Input Unit Factor: 1
Output Projection Parameters: +proj=lcc +lat_1=36.16666666666666
+lat_2=34.33333333333334 +lat_0=33.75 +lon_0=-79 +x_0=609601.22 +y_0=0
+no_defs +a=6378137 +rf=298.257222101 +towgs84=0.000,0.000,0.000
Output Unit Factor: 1
D3/5: region item: proj: 3
D3/5: region item: north: 35:54:41.000547N
D3/5: region item: south: 35:35:17.001098N
D3/5: region item: east: 78:27:08.000616W
D3/5: region item: west: 78:49:17.999987W
D3/5: region item: cols: 1330
D3/5: region item: rows: 1164
D3/5: region item: e-w resol: 0:00:01
D3/5: region item: n-s resol: 0:00:01
D3/5: region item: format: -1
D3/5: region item: compressed: 1
D3/5: G_adjust_Cell_head: epsilon_ns: 8.59107e-07, epsilon_ew: 1e-06
D1/5: G_find_raster(): name=MASK mapset=user1
D3/5: Top: xmin: -78.452221; xmax: -78.821668; ymin: 35.911390; ymax:
35.588055
D3/5: Right: xmin: -78.452221; xmax: -78.821668; ymin: 35.911390; ymax:
35.588055
D3/5: Bottom: xmin: -78.452221; xmax: -78.821668; ymin: 35.911390; ymax:
35.588055
D3/5: Left: xmin: -78.452221; xmax: -78.821668; ymin: 35.911390; ymax:
35.588055
D3/5: Extra check: xmin: -78.821528; xmax: -78.452361; ymin: 35.588195;
ymax: 35.911250
D3/5: Final check: xmin: -78.821667; xmax: -78.452222; ymin: 35.588056;
ymax: 35.911389
D3/5: Top: xmin: 625709.948811; xmax: 659030.331786; ymin: 239768.184363;
ymax: 239890.045778
D3/5: Right: xmin: 625709.948811; xmax: 659228.054367; ymin:
204049.351740; ymax: 239890.045778
D3/5: Bottom: xmin: 625709.948811; xmax: 659228.054367; ymin:
203927.002865; ymax: 239890.045778
D3/5: Left: xmin: 625709.948811; xmax: 659228.054367; ymin: 203927.002865;
ymax: 239890.045778
D3/5: Extra check: xmin: 625709.948811; xmax: 659228.054367; ymin:
D3/5: Final check: xmin: 625500.000000; xmax: 659500.000000; ymin:
203500.000000; ymax: 240000.000000
Segmentation fault
I can run a shell debugger on this again if needed.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:14>
