[GRASS-dev] 6.4.1 blocker bugs - import common formats
Helena Mitasova
hmitaso at unity.ncsu.edu
Thu Jan 27 14:41:07 EST 2011
regarding the troubles with import/export, one of the issues that put
users on dead path was the default setting on the
Import vector data>common formats
By default the File button is switched on but when you go to the
directory where the shape files are,
they are all grayed out and .shp file cannot be selected.
going back and switching the Directory button on and then selecting
the directory where the shape file is works,
so I am wondering whether the Directory button should be switched on
by default,
or if the File option is preferable perhaps there is bug that does not
allow to select the file?
Helena
