[GRASS-dev] 6.4.1 blocker bugs?
Martin Landa
landa.martin at gmail.com
Fri Jan 28 09:38:00 EST 2011
2011/1/28 Helena Mitasova <hmitaso at unity.ncsu.edu>:
> but
> d.legend starts the completion bar in map display but stalls
> one has to remove a no-name layer from Map layers to get rid of the stall
> reason, exception),
> TypeError
> unsupported operand type(s) for +: 'GException' and
> 'unicode'
> For those that are not implemented it suggests to add it as command layer - do we still have command layer?
> do we need to change the suggestion - just say "not implemented"?
> and for
> d.barscale : - not implemented yet, try add it as command layer instead
> it may be "try add it as Add map elements"
now should be OK for d.legend and d.barscale - please check out r45237.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
