[GRASS-dev] MinGW/MSYS Build
Huddleston, John
Huddleston at cira.colostate.edu
Fri Jan 28 09:38:17 EST 2011
Hi
I have starting building GRASS6.4.1RC1 under the native Windows MinGW/MSYS (not Cygwin) environment.
Most of the build is straight forward; although, I did have to modify the psdriver area slightly since there is a duplicate init_color_table function under the pngdriver.
Now I am up to the point where it requires the X11 libraries. Does anyone have any experience building X11 under MinGW? Should I be using XFree86-4.8.0 or some other source.
Any insight would be most appreciated.
Thank you,
John Huddleston, PhD
