[GRASS-dev] Re: [GRASS GIS] #1262: r.proj broken in all dev versions
GRASS GIS trac at osgeo.org
Fri Jan 28 20:20:29 EST 2011
 Reporter:  cmbarton              |       Owner:  grass-dev@…
     Type:  defect                |      Status:  new
 Priority:  critical              |   Milestone:  6.4.1
Component:  Raster                |     Version:  unspecified
 Keywords:  r.proj, reprojection  |    Platform:  MacOSX
      Cpu:  OSX/Intel             |
Comment(by hellik):
 Replying to [comment:26 cmbarton]:
 > It still is very important to fix for 7.0. Since it is broken on the
 Mac, I'm betting it's still broken for Windows in 7.0 too, but this needs
 testing.
 tested with WinGRASS-7.0.SVN-r45224-1-Setup.exe (nightly build of today).
 again with source: +proj=tmerc target: +proj=longlat
 it's very interesting, something is crashing during reprojecting, but the
 raster itself is reprojected.
 r.proj input=DemEuropeFPp100nn location=ak_noe3 mapset=data
 output=test3debug
 D1/3: G_find_raster(): name=test3debug mapset=user1
 D2/3: G__read_Cell_head
 D2/3: G__read_Cell_head_array
 D3/3: region item: proj:       3
 D3/3: region item: zone:       0
 D3/3: region item: north:      60N
 D3/3: region item: south:      30N
 D3/3: region item: east:       30E
 D3/3: region item: west:       0
 D3/3: region item: cols:       3600
 D3/3: region item: rows:       3600
 D3/3: region item: e-w resol:  0:00:30
 D3/3: region item: n-s resol:  0:00:30
 D3/3: region item: top:        1
 D3/3: region item: bottom:     0
 D3/3: region item: cols3:      3600
 D3/3: region item: rows3:      3600
 D3/3: region item: depths:     1
 D3/3: region item: e-w resol3: 0:00:30
 D3/3: region item: n-s resol3: 0:00:30
 D3/3: region item: t-b resol:  1
 D3/3: G_adjust_Cell_head: epsilon_ns: 2.77778e-007,
 epsilon_ew: 1e-006
 D1/3: G_find_raster(): name=DemEuropeFPp100nn mapset=data
 D1/3: G_find_raster2(): name=DemEuropeFPp100nn mapset=data
 D3/3: adding rule 79=79.00 0 191 191  498=498.20 0 255 0
 D3/3: adding rule 498=498.20 0 255 0  917=917.40 255 255 0
 D3/3: adding rule 917=917.40 255 255 0  1336=1336.60 255 127
 0
 D3/3: adding rule 1336=1336.60 255 127 0  1755=1755.80 191
 127 63
 D3/3: adding rule 1755=1755.80 191 127 63  2175=2175.00 20
 20 20
 D3/3: region item: proj:       99
 D3/3: region item: north:      432254.46875
 D3/3: region item: south:      253707.0625
 D3/3: region item: east:       804844.1875
 D3/3: region item: west:       610026.4375
 D3/3: region item: cols:       1948
 D3/3: region item: rows:       1785
 D3/3: region item: e-w resol:  100.00911191
 D3/3: region item: n-s resol:  100.02655812
 D3/3: region item: format:     -1
 D3/3: region item: compressed: 1
 D1/3: G_find_raster(): name=MASK mapset=user1
 D3/3: Top: xmin: 804844.187501; xmax: 610026.437499; ymin:
 432254.468751; ymax: 253707.062499
 D3/3: Right: xmin: 804844.187501; xmax: 610026.437499; ymin:
 D3/3: Bottom: xmin: 804844.187501; xmax: 610026.437499;
 ymin: 432254.468751; ymax: 253707.062499
 D3/3: Left: xmin: 804844.187501; xmax: 610026.437499; ymin:
 D3/3: Extra check: xmin: 610076.442056; xmax: 804794.182944;
 ymin: 253757.075779; ymax: 432204.455471
 D3/3: Final check: xmin: 610026.437500; xmax: 804844.187500;
 ymin: 253707.062500; ymax: 432254.468750
 D3/3: Top: xmin: 14.419322; xmax: 17.081289; ymin:
 49.011643; ymax: 49.027566
 D3/3: Right: xmin: 14.419322; xmax: 17.081289; ymin:
 47.420479; ymax: 49.027566
 D3/3: Bottom: xmin: 14.419322; xmax: 17.081289; ymin:
 47.407697; ymax: 49.027566
 D3/3: Left: xmin: 14.419322; xmax: 17.081289; ymin:
 D3/3: Extra check: xmin: 14.419322; xmax: 17.081289; ymin:
 D3/3: Final check: xmin: 14.416667; xmax: 17.083333; ymin:
 47.400000; ymax: 49.033333
 epsilon_ew: 1e-006
 D3/3: G_adjust_Cell_head: epsilon_ns: 5.10204e-006,
 epsilon_ew: 1e-006
 epsilon_ew: 1e-006
 Eingabe:
 Spalten: 1948 (1948)
 Zeilen: 1785 (1785)
 Norden: 432254.468750 (432254.468750)
 Süden: 253707.062500 (253707.062500)
 Westen: 610026.437500 (610026.437500)
 Osten: 804844.187500 (804844.187500)
 EW-res: 100.009112
 NS-res: 100.026558
 Ausgabe:
 Spalten: 320 (3600)
 Zeilen: 196 (3600)
 Norden: 49.033333 (60.000000)
 Süden: 47.400000 (30.000000)
 Westen: 14.416667 (0.000000)
 Osten: 17.083333 (30.000000)
 EW-res: 0.008333
 NS-res: 0.008333
 D3/3: create window mapping (1948 columns)
 Allokiere Speicher und lese die Eingabekarte...
 epsilon_ew: 1e-006
 epsilon_ew: 1e-006
 Projeziere...
 D1/3: close test3debug compressed
 D1/3: G_find_raster2(): name=test3debug mapset=user1
 D3/3: G_recreate_command()
 (Sat Jan 29 02:14:39 2011) Command finished (10 sec)
 somewhere around here
 there seems to be a crash (a windows-warning-messages pops up)
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1262#comment:27>
