[GRASS-dev] Re: [GRASS GIS] #699: v.buffer segfault: in
Vect_get_isle_points()
trac at osgeo.org
Sun Jan 30 06:58:10 EST 2011
#699: v.buffer segfault: in Vect_get_isle_points()
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: 6.4.0 RCs
Keywords: v.buffer | Platform: All
Cpu: All |
Comment(by mlennert):
Replying to [comment:13 mmetz]:
> If this bug can not be resolved I would suggest to reactivate the
original versions of v.buffer and v.parallel (the bugs described there are
easy to fix within the module without touching the libs) and deactivate
v.buffer2 and v.parallel2.
I can't remember what the issues were triggering the rewrite of v.buffer,
but if you think you can solve these issues and that that the original
v.buffer is much faster, you definitely have my +1.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/699#comment:14>
