[GRASS-dev] Re: Variable quoting problem (and solution)
Markus Neteler
neteler at osgeo.org
Sun Jan 30 12:23:14 EST 2011
On Sun, Jan 30, 2011 at 2:14 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Sun, Jan 30, 2011 at 1:26 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Done in r45247 (6.4) and r45248 (6.5).
Now the wxGUI is finally generated properly on Windows (will be valid also for
a series of other scripts) in case that the installation path contains
white space.
A wxGUI problem remains (received from Helmut), autogenerated GUI
command:
v.in.geonames --verbose input=C:\dl\AT\AT.txt output=vingeowxgui
ERROR: File 'C:dlATAT.txt' not found
(Sun Jan 30 17:31:15 2011) Command finished (1 sec)
While it now works on command line (when quoting the input path/file, otherwise
not), it still fails in the GUI.
Any chance to protect the backslashes in the GUI environment?
Markus
