[GRASS-dev] [GRASS GIS] #1397: Lat/lon compatibility for r.water.outlet
GRASS GIS trac at osgeo.org
Sat Jul 2 21:01:19 EDT 2011
 Reporter:  awickert  |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  6.4.2
Component:  Raster    |     Version:  svn-releasebranch64
 Keywords:            |    Platform:  Linux
      Cpu:  x86-64    |
 Adding the attached line to r.water.outlet allows it to work across the
 180 meridian in lat/lon coordinate systems.
 I believe that the GRASS command G_adjust_east_longitude() is flagged to
 work only in lat/lon coordinate systems, so there should not be backwards-
 compatibility issues, but I haven't tested it with a projected coordinate
 system.
 It might be good as well to change to documentation to reflect that the
 Northing and Easting can also be Latitude and Longitude.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1397>
