[GRASS-dev] Re: GRASS Test suite
Soeren Gebbert soerengebbert at googlemail.com
Mon Jul 4 04:56:56 EDT 2011
Hi Anne,
2011/7/4 Anne Ghisla <a.ghisla at gmail.com>:
> Le dimanche 03 juillet 2011 à 15:53 -0700, Hamish a écrit :
>> Hi,
>> can we move the test files into $MODULE/testsuite/ or similar?
>> I'm just looking at grass7/raster/r.colors/ and the test files
>> really dominate the module dir.
> +1 from me on having a testsuite/ or tests/ subdir for each module.
> I'm starting to implement the test framework, it will be in
> trunk/testsuite. Hints on how to modify the Makefile are welcome!
Thank you for starting the implementation. If you have any tiny
question, don't bother to ask. I hope the whole test suite picture
comes much clearer when some basic framework is available to play
around a with.
Important: in case the test script approach which i have used for the
test cases in the g3d modules is not sufficient, i will modify them to
fit the new guidelines and insights.
Best regards
Soeren
> best,
> Anne
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
