[GRASS-dev] [GRASS GIS] #1398: problem with multiple entry selection
trac at osgeo.org
Wed Jul 6 02:49:57 EDT 2011
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: 6.4.1 RCs
Keywords: multiple entries, multiple selections | Platform: All
Cpu: All |
For commands that allow for multiple entry selections, the entry cannot be
edited in the gui dialog. Example: For a command like r.report, select
map1, map2, map3 and press run. Then delete map1 and map2 from the list in
the map selection control. Press run and r.report is run on map1, map2,
and map3 again.
In gselect.py, when multiple=True, all selections are stored to a list.
New selections are appended to that list. But the list is not updated with
values actually in the control. So any edits to the list of maps (or other
items) is not recognized. I think this is happening in line 493, but I
can't find a way to update the list of multiple values (self.value) with
the items that are actually in the control.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1398>
