[GRASS-dev] Python scripts- 2 small questions
Luca Delucchi
lucadeluge at gmail.com
Thu Jul 7 08:08:22 EDT 2011
2011/7/6 António Rocha <antonio.rocha at deimos.com.pt>:
> 1- is there any way or module that can be used to check if current machine
> is a 32b or 64b?
i think that you can use platform.architecture()
> 2- is there any way to check if a produced GRID ASCII was correctly built?
maybe you can create a function with python gdal, if it is possible to
read the file it's correct otherwise not
> Thanks
> Antonio
regards
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
