[GRASS-dev] Re: [GRASS GIS] #1401: r.series for time series
trac at osgeo.org
Mon Jul 11 23:51:48 EDT 2011
Reporter: mmetz | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: raster, time series | Platform: All
Cpu: All |
Comment(by glynn):
Replying to [comment:5 mmetz]:
> I will try to explain the motivation for this patch with an example.
Okay, so you're filtering in the time domain, then taking a single sample
from the middle of the interval?
Even so, I would suggest making the "radius" (i.e. cut-off frequency) a
parameter, and probably also the centre (although that can be fudged by
padding with null maps).
In general, the cut-off frequency shouldn't depend upon the filtering
method; the reason the various filters in r.resamp.filter have associated
radii is so that the cut-off frequency doesn't vary with the filter method
(i.e. the user-supplied radius value is normalised).
Also, if you're likely to want more than one output, extending r.series to
support multiple outputs (with different offsets) would be significantly
more efficient than multiple runs of r.series (reading the inputs could
easily take more time than the actual processing).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1401#comment:6>
