[GRASS-dev] strange mapcalc result
Michael Barton
Michael.Barton at asu.edu
Tue Jul 12 02:19:50 EDT 2011
In the even that this might be the case, I also tried creating a new map
r.mapcalc expression='SRTM_ffB03_p199r033_2=if(SRTM_ffB03_p199r033==-32768,null(),SRTM_ffB03_p199r033)'
...and got the same result with the new map.
r.null does work of course.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Jul 11, 2011, at 8:54 PM, Glynn Clements wrote:
> Michael Barton wrote:
>> This is from GRASS 7 compiled from svn trunk yesterday.
>> I'm simply trying to assign null values in an SRTM using r.mapcalc. I do the following statement...
>> r.mapcalc expression='SRTM_ffB03_p199r033=if(SRTM_ffB03_p199r033==-32768,null(),SRTM_ffB03_p199r033)' --o
>> The entire map turns to null.
>> Any idea what I'm doing wrong?
> Using the same map for input and output results in undefined
> behaviour. If you want to change a value to null "in place", use
> r.null.
> Glynn Clements <glynn at gclements.plus.com>
