[GRASS-dev] Segmentation fault using v.in.lidar
Pierre Roudier
pierre.roudier at gmail.com
Wed Jul 13 03:05:17 EDT 2011
Thanks for the quick answer Markus,
That would be a nice feature to add though. A lot of the LAS files are
coming "tiled", and it'd be nice to be able to do something like:
v.in.lidar in=*.las out=test_input_lidar -trb
or
v.in.lidar in=zone_32_*.las out=test_input_lidar -trb
to import a special subset of LAS files.
I've very few coding abilities, so this is just meant as another line
on the wishlist ;)
Thanks heaps for your work on *.in.lidar, it is working well otherwise,
Pierre
2011/7/13 Markus Metz <markus.metz.giswork at googlemail.com>:
> On Wed, Jul 13, 2011 at 2:08 AM, Pierre Roudier
> <pierre.roudier at gmail.com> wrote:
>> Hi,
>> I've been trying to use v.in.lidar. It yields good results on one LAS
>> file, but I get a segfault when trying it on several files:
>>> v.in.lidar in=BD32_1610.las,BD32_1611.las out=test_input_lidar -trb
>> Segmentation fault
>>> v.in.lidar in=BD32_161*.las out=test_input_lidar -trb
>> Segmentation fault
>> Am I missing something, or is it a bug?
> v.in.lidar takes only one input file at a time.
> Markus M
Scientist
Landcare Research, New Zealand
