[GRASS-dev] Python Scripting Library: mogrify command
Massimiliano Cannata
massimiliano.cannata at supsi.ch
Wed Jul 13 08:04:03 EDT 2011
Thanks Glynn for clarification,
I will go with the make_command()...
Maxi
On 07/13/2011 11:26 AM, Glynn Clements wrote:
> Massimiliano Cannata wrote:
>> I was wandering: does exist a python::core function capable to mogrigy
>> the inputs of a run_command()?
>> The mogrify function for psycopg2 is defined as follows:
>> "/Return a query string after arguments binding. The string returned is
>> exactly the one that would be sent to the database running the execute()
>> method or similar./"
>> >>> cur.mogrify("INSERT INTO test (num, data) VALUES (%s, %s)", (42,
>> 'bar'))
>> "INSERT INTO test (num, data) VALUES (42, E'bar')"
>> ...so for GRASS it could be:
>> >>> grass.mogrify_command("r.univar",flags="g",map="test")
>> "r.univar -g map=test"
> make_command() returns an argument list, e.g.:
> > import grass.script as grass
> > grass.make_command("r.univar",flags="g",map="test")
> ['r.univar', '-g', 'map=test']
> This is what all of the *_command() functions use to generate the
> argument list.
> Converting an argument list to a string is non-portable (/bin/sh has
> significantly different syntax to cmd.exe) and quite tricky unless
> you're willing to blindly quote everything to be on the safe side,
> e.g. (for /bin/sh):
> args = [arg.replace("'", "'\\''") for arg in args]
> cmdstr = "'" + "' '".join(args) + "'"
> It's much harder for Windows; see:
> http://msdn.microsoft.com/en-us/library/17w5ykft.aspx
> or escape_arg() in lib/gis/spawn.c, or list2cmdline() in Python's
> subprocess.py.
> Note that none of the *_command() functions construct a command
> string; they pass the argument list to subprocess.Popen() which
> eventually either passes it to execve() (on Unix) or uses
> list2cmdline() (on Windows).
Dr. Eng. Massimiliano Cannata
Responsabile Area Geomatica
Istituto Scienze della Terra
Scuola Universitaria Professionale della Svizzera Italiana
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)58 666 62 14
Fax +41 (0)58 666 62 09
