[GRASS-dev] Re: [GRASS-user] Compiling GRASS 7.0 error with tcl.h
Glynn Clements
glynn at gclements.plus.com
Sat Jul 16 05:23:21 EDT 2011
S. Koukoulas wrote:
> I am trying to compile GRASS 7 svn (9Jul2011) snapshot on Ubuntu natty
> (11.04) but without any success.
> configure:10381: checking for tcl.h
> configure:10389: gcc -E /usr/include/tcl -I/usr/include/tcl8.5
> conftest.c >/dev/null 2>conftest.out
> gcc: /usr/include/tcl: linker input file unused because linking not done
I suspect that TCLINCDIR is set in the environment; unset it.
For grass-dev:
We might want to change LOC_CHECK_INC_PATH (and similar) to explicitly
clear the variable, e.g.:
Index: aclocal.m4
--- aclocal.m4 (revision 47135)
+++ aclocal.m4 (working copy)
@@ -19,6 +19,7 @@
esac
AC_MSG_RESULT($with_$1_includes)
+$3=
if test -n "$with_$1_includes" ; then
for dir in $with_$1_includes; do
if test -d "$dir"; then
