[GRASS-dev] Parser problem in GRASS 7
Markus Neteler
neteler at osgeo.org
Mon Jul 18 05:46:43 EDT 2011
On Sat, Jul 16, 2011 at 11:29 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> by chance I came across a strange problem:
>> # wrong param name "inbut":
>> GRASS 7.0.svn (spearfish60):~ > r.colors inbut=diff col=differences
>> Aborted
>> Any wrong name currently leads to "Abort" rather than the expected error
>> message from the parser. They are generated, then get lost.
>> Here the backtrace:
> Try r47136.
Much better, thanks. Just a minor observation:
raster Raster map from which to copy color table
volume Raster3d map from which to copy color table
rules Path to rules file
"-" to read rules from stdin
ERROR:
ERROR: Required parameter <map> not set:
(Name of raster map)
-> there is a first empty, ERROR, maybe an initialization issue?
Markus
