[GRASS-dev] Re: [GRASS GIS] #1353: ./configure with ffmpeg x86_64 -
problem, with workaround
trac at osgeo.org
Mon Jul 18 05:57:42 EDT 2011
#1353: ./configure with ffmpeg x86_64 - problem, with workaround
Reporter: geep999 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 6.4.1 RCs
Keywords: | Platform: Linux
Cpu: x86-64 |
Comment(by geep999):
Replying to [comment:1 glynn]:
> Replying to [ticket:1353 geep999]:
> > This happens because ./configure is looking for:
> > /usr/lib64/libavcodec.so /usr/lib64/libavformat.so
/usr/lib64/libavutil.so
> > But on my 64bit Slackware 13.37 they are installed in:
> > /usr/lib64/libavcodec64.so /usr/lib64/libavformat64.so
/usr/lib64/libavutil64.so
> > Making soft links cures the problem, but perhaps ./configure could be
upgraded.
> What does:
> pkg-config --libs libavcodec
> say?
> If it points to the 64-bit libraries, we could try that. OTOH, if the
64-bit version is a separate package (from pkg-config's perspective), that
doesn't help.
-lavcodec64
Ticket URL: <http://trac.osgeo.org/grass/ticket/1353#comment:3>
