[GRASS-dev] strange mapcalc result
    Glynn Clements
    glynn at gclements.plus.com
    Mon Jul 18 15:19:06 EDT 2011
Markus Neteler wrote:
> (note the white spaces around "=", which is required in GRASS7 - a bit
> unfortunate...)
It shouldn't be required if you explictly specify the "expression=".
It should only be required if "expression=" is omitted, to ensure that
the parser treats it as a "default option" argument and not an
option=value argument.
