[GRASS-dev] [GRASS GIS] #1406: g.extension fails on Mac (maybe
other platforms too?)
trac at osgeo.org
Tue Jul 19 01:38:33 EDT 2011
#1406: g.extension fails on Mac (maybe other platforms too?)
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: Compiling | Version: unspecified
Keywords: extension | Platform: MacOSX
Cpu: OSX/Intel |
Working in the current svn version of GRASS 7, I tried to install r.stream
via g.extension. First, I tried from the command line in the terminal.
Here is what happened.
GRASS 7.0.svn (Spain_wgs84z30):~ > g.extension -s extension=wx.stream
ERROR: install required. Please install 'install' first.
Then I tried from the g.extension menu item from the settings menu. Here
is what I got in the console output window.
File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc
/gui/wxpython/wxgui.py", line 1035, in OnInstallExtension
win = InstallExtensionWindow(self, size = (650, 550))
File "/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-
darwin10.8.0/etc/gui/wxpython/gui_modules/ghelp.py", line
832, in __init__
self.statusbar = self.CreateStatusBar(0)
/python/wx/_windows.py", line 538, in CreateStatusBar
return _windows_.Frame_CreateStatusBar(*args, **kwargs)
wx._core
PyAssertionError
C++ assertion "m_nFields == (int)m_statusStrings.GetCount()"
failed at /BUILD/wxPython-
src-2.8.12.0/src/generic/statusbr.cpp(136) in
SetFieldsCount(): This really should never happen, can we do
away with m_nFields here?
Finally, I tried to launch g.extension from the terminal command line. The
module launches. But when I try to install r.stream, I get the same
"ERROR: install required. Please install 'install' first."
message.
Then I tested in the GRASS 6 series.
g.extension launches fine in both 6.5 and 6.4.2. However, almost
everything fails to compile because...
make: *** No targets specified and no makefile found. Stop.
However, the r.stream.* modules do compile because they ignore targets set
and put everything on the desktop.
In all cases, the values set for GRASS_ADDON_PATH is ignored by
g.extension.
[An aside: it is not possible to pick 6.4.2 or all versions for the
version in the online trac application]
Ticket URL: <http://trac.osgeo.org/grass/ticket/1406>
