[GRASS-dev] GRASS_RENDER_IMMEDIATE in GRASS7
Wed Jul 20 07:09:09 EDT 2011
Hamish wrote:
> > Hamish wrote:
> > > which variables exactly would be better controlled by
> > > modules directly?
> Glynn:
> > Anything where you want the user to be able to change the
> > setting via a module rather than requiring the user to use
> > "export" or "eval `...`".
> I ask because I'm having trouble imagining examples.
If you want something like d.mon with GRASS 7, then the driver-related
environment variables need to be moved to a file.
