[GRASS-dev] [GRASS GIS] #1408: WxNviz is crashing in GRASS 7 svn
GRASS GIS trac at osgeo.org
Thu Jul 21 21:05:23 EDT 2011
 Reporter:  PierreRoudier  |       Owner:  grass-dev@…
     Type:  defect         |      Status:  new
 Priority:  normal         |   Milestone:  7.0.0
Component:  Default        |     Version:  svn-trunk
 Keywords:  nviz           |    Platform:  Linux
      Cpu:  x86-64         |
 I can't switch to 3D view in GRASS 7 svn (rev 47218), it crashes all the
 GUI (including the layer manager) and yields the following error message:
 GRASS 7.0.svn (NZTM2000):/data/GRASSDATA >
 (wxgui.py:4098): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to
 allocate widget with width -2 and height 14
 The program 'wxgui.py' received an X Window System error.
 This probably reflects a bug in the program.
 The error was 'BadDrawable (invalid Pixmap or Window parameter)'.
   (Details: serial 9955 error_code 9 request_code 137 minor_code 8)
   (Note to programmers: normally, X errors are reported asynchronously;
    that is, you will receive the error a while after causing it.
    To debug your program, run it with the --sync command line
    option to change this behavior. You can then get a meaningful
    backtrace from your debugger if you break on the gdk_x_error()
 function.)
 Tested on spearfish and personal locations, with or without raster data
 loaded in the 2D viewer, with or without vector data loaded in the 2D
 viewer.
 I'm running Linux-64 bits (Opensuse 11.3).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1408>
