[GRASS-dev] Re: ctypes problem with Vect_open_old
Sat Jul 23 10:12:33 EDT 2011
Martin Landa wrote:
> sorry, small bug in my sample test. Here is a new attempt - sample script:
> #!/usr/bin/python
> from grass.lib.gis  import *
> from grass.lib.vector import *
> map_obj = Map_info()
> map = pointer(map_obj)
> print os.environ['PYTHONPATH']
> print sizeof(off_t)
> Vect_open_update(map, "a", "")
> *** glibc detected *** /usr/bin/python: malloc(): memory corruption:
> 0x09ba9fe8 ***
Does calling G_gisinit() first change anything?
