[GRASS-dev] Re: [GRASS GIS] #1408: WxNviz is crashing in GRASS 7 svn
trac at osgeo.org
Sun Jul 24 19:07:16 EDT 2011
Reporter: PierreRoudier | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: nviz | Platform: Linux
Cpu: x86-64 |
Comment(by PierreRoudier):
Sorry Anna, I can't remember having it working at all on that machine. I
always make distclean before compiling.
It seems to be specific to my Opensuse box though, because I tried WxNviz
successfully over the week-end on my laptop, which is running Ubuntu.
Here's the debug messages on the spearfish dataset (just the last lines as
it was a very long log):
D5/5: _gsdrape_get_segments vi=1, hi=2, di=0, num=5
D5/5: gs_get_att_typbuff(): id=110658 desc=1 to_write=0
D5/5: gs_get_att_src(): id=110658, desc=1
D5/5: _gsdrape_get_segments vi=1, hi=2, di=4, num=9
D3/5: GS_global_exag(): 1
D5/5: _gsdrape_get_segments vi=2, hi=2, di=0, num=6
D5/5: _gsdrape_get_segments vi=2, hi=2, di=3, num=9
D5/5: _gsdrape_get_segments vi=2, hi=2, di=4, num=10
D5/5: Drawing site 21720 on Surf 110658
D3/5: GS_done_draw
D3/5: GS_ready_draw
D3/5: GS_get_zrange(): min=1061.11 max=1846.39
D3/5: GS_get_aspect(): left=0, right=19, top=19, bottom=0
D3/5: GS_done_draw
D3/5: GS_done_draw
The program 'python' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadDrawable (invalid Pixmap or Window parameter)'.
(Details: serial 39515 error_code 9 request_code 137 minor_code 8)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error()
function.)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1408#comment:6>
