[GRASS-dev] [GRASS GIS] #1409: wxGUI command console does not parse
correctly "help" and first parameter
trac at osgeo.org
Mon Jul 25 14:03:35 EDT 2011
#1409: wxGUI command console does not parse correctly "help" and first parameter
Reporter: philippbs | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: wxGUI | Version: svn-releasebranch64
Keywords: | Platform: MSWindows 7
Cpu: x86-64 |
The wxGUI command line console does not parse commands correctly,
critically the 'help' option does not work. e.g.
d.vect help
results in
ERROR: Rendering failed
and erases the map display and it leads to the undesired creation
of a layer 'help' in the Map Layers tab.
Similarly, implicit parameter declarations are not parsed, e.g. (using the
North Carolina dataset)
d.vect streams
results in the same error message as above and the creation of a layer
'streams' in Map Layers.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1409>
