[GRASS-dev] Re: [GRASS GIS] #1408: WxNviz is crashing in GRASS 7 svn
trac at osgeo.org
Tue Jul 26 18:14:09 EDT 2011
Reporter: PierreRoudier | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: nviz | Platform: Linux
Cpu: x86-64 |
Comment(by PierreRoudier):
Thanks Wenzeslaus,
I tried the demo and the two GLCanvas demo are crashing on my box.
roudierp at A208_RoudierP:/tmp> python wxPython-2.8.11.0/demo/demo.py
The program 'python' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadDrawable (invalid Pixmap or Window parameter)'.
(Details: serial 17272 error_code 9 request_code 137 minor_code 8)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error()
function.)
I guess that means that this is a problem on my configuration, and that it
is not related to WxNviz code.
Pierre
Ticket URL: <http://trac.osgeo.org/grass/ticket/1408#comment:18>
