[GRASS-dev] [GRASS GIS] #1414: v.in.gshhs broken for data version 2.2.0
GRASS GIS trac at osgeo.org
Thu Jul 28 13:04:41 EDT 2011
 Reporter:  dickeya  |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:
Component:  Vector   |     Version:  svn-releasebranch64
 Keywords:           |    Platform:  Linux
      Cpu:  x86-64   |
 I'm getting a failure when trying to run v.in.gshhs on the new version
 2.2.0 data set.  I downloaded the files from
 http://www.soest.hawaii.edu/pwessel/gshhs/.
 v.in.gshhs in=gshhs_f.b out=gshhs_f_v220 --o
 Using lat/lon bounds N=90.000000 S=-90.000000 E=180.000000 W=-180.000000
 ERROR: Trying to import version 3, only GSHHS versions 4 to 8 (2.0) are
 supported.
 The README file with the data mentions that greenwich flag in the header
 was expanded from 1 bit to 2.  Maybe that is offsetting which value is
 getting read for the version info.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1414>
