[GRASS-dev] strange mapcalc behavior again
Glynn Clements
glynn at gclements.plus.com
Thu Jul 28 15:03:38 EDT 2011
Michael Barton wrote:
> Somehow, the 2nd part of the if clause is being ignored. I've done
> this in GRASS 6.5 and 7 with the same results (with the changed of
> syntax needed for GRASS 7). Am I missing something here?
If such a fundamental error existed in r.mapcalc itself, I'm fairly
sure that you wouldn't be the only person seeing it. So it would seem
to be a problem with your system, your GRASS build, or your data.
Unfortunately, I have no idea what.
Do you get odd results for any module other than r.mapcalc?
