[GRASS-dev] Re: ctypes problem with Vect_open_old
Martin Landa
landa.martin at gmail.com
Thu Jul 28 17:35:36 EDT 2011
2011/7/28 Glynn Clements <glynn at gclements.plus.com>:
> The simplest fix is probably to add -D__GLIBC_HAVE_LONG_LONG to
> CTYPESFLAGS in lib/python/ctypes/Makefile. That macro is unlikely to
> be understood by anything other than glibc, and any system using glibc
> is almost certain to be using a compiler which supports "long long".
I modified Makefile
CTYPESFLAGS = --cpp "$(CC) -E $(CPPFLAGS) $(LFS_CFLAGS)
$(EXTRA_CFLAGS) $(NLS_CFLAGS) $(DEFS) $(EXTRA_INC) $(INC)
-D__GLIBC_HAVE_LONG_LONG"
after recompilation I can see in vector.py
__quad_t = c_longlong # /usr/include/i386-linux-gnu/bits/types.h: 56
__off_t = c_long # /usr/include/i386-linux-gnu/bits/types.h: 141
__off64_t = __quad_t # /usr/include/i386-linux-gnu/bits/types.h: 142
Unfortunately the sample script still fails
D1/5: Vect_open_sidx(): name = a mapset= landa mode = update
D1/5: get coor info: /home/martin/grassdata/nc_spm_08/landa/vector/a/coor
D1/5: Info->size = 76, Info->mtime = 1311887704
D2/5: Spidx header: file version 5.1 , supported from GRASS version 5.1
D2/5: byte order 0
D2/5: header size 113
D2/5: with_z 0
D2/5: coor size 76
D1/5: Sidx head: coor size = 76, coor mtime = 0
D1/5: Memory based spatial index
D1/5: dig_read_spindx()
D2/5: byte order 0
D2/5: with_z 0
D2/5: coor size 76
*** glibc detected *** python: malloc(): memory corruption: 0x086b5908 ***
Any idea where could be a problem?
Thanks, Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
