[GRASS-dev] odd configure error on MacOS X
Dylan Beaudette
dylan.beaudette at gmail.com
Fri Jul 29 04:34:50 EDT 2011
On Thu, Jul 28, 2011 at 9:00 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Dylan Beaudette wrote:
>> With this morning's SVN from GRASS 6.5 and 7, I am getting a strange
>> error on the configure step:
>> checking for cairo_create... no
>> configure: error: *** Unable to locate .
>> ^^^^^ <- this is a
>> strange error!
>> Any ideas?
> The error message should have been "Unable to locate cairo_create";
> this has been fixed for 7.0 with r47301.
> This doesn't affect the fact that you're getting the error, just the
> message. Check the bottom of config.log for clues as to why the test
> failed.
> Glynn Clements <glynn at gclements.plus.com>
Thanks Glynn.
Here is the relevant section from config.log:
configure:12938: checking for cairo_create
configure:12964: gcc -o conftest -g -O2 -arch i386 -I/usr/include
-arch i386 -L/usr/lib conftest.c -L/sw/lib -
lcairo -L/sw/lib -lfontconfig 1>&5
ld: library not found for -lfontconfig
collect2: ld returned 1 exit status
configure: failed program was:
#line 12941 "configure"
#include "confdefs.h"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char cairo_create(); below. */
#include <assert.h>
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
int main() {
/* The GNU C library defines this for functions which it implements
to always fail with ENOSYS. Some functions are actually named
something starting with __ and the normal name is an alias. */
#if defined (__stub_cairo_create) || defined (__stub___cairo_create)
choke me
#else
cairo_create();
#endif
; return 0; }
... updated to latest SVN, and now configure outputs a more useful
error message:
configure: error: *** Unable to locate cairo_create.
... removing '--with-cairo-ldflags=-lfontconfig' allows configure to
complete, and running make results in:
gcc -I/usr/include -g -O2 -arch i386 -fno-common -I/usr/include
-I/Users/dylan/src/grass_trunk/dist.i386-apple-darwin9.8.0/include
-D_FILE_OFFSET_BITS=64 -I../driver -I/usr/X11/include/libpng12
-I/usr/X11/include -I/usr/X11/include/freetype2 -I/sw/include
-I/sw/include/cairo -I/sw/include/cairo -I/usr/X11/include
-DUSE_X11=1 -DPACKAGE=\""grasslibs"\"
-I/Users/dylan/src/grass_trunk/dist.i386-apple-darwin9.8.0/include -o
OBJ.i386-apple-darwin9.8.0/Graph.o -c Graph.c
Graph.c:19:23: error: cairo-svg.h: No such file or directory
... look like I need to do some more homework.
Thanks,
Dylan
