[GRASS-dev] [GRASS GIS] #1415: closecell: can't move + quant file
error in winGRASS Msys shell
trac at osgeo.org
Fri Jul 29 05:41:58 EDT 2011
#1415: closecell: can't move + quant file error in winGRASS Msys shell
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: Default | Version: svn-releasebranch64
Keywords: | Platform: MSWindows XP
Cpu: Unspecified |
Running v.surf.bspline in the MSys shell leads to a quant file error (in
the wxGUI command console no such problem!):
v.surf.bspline input=ahn5m raster=ahn5m_interp sie=15
sin=15 method=bicubic lambda_i=0.05
No vector map of sparse points to interpolate was specified.
Interpolation will be done with <ahn5m> vector map
subregion 1 of 6
subregion 2 of 6
subregion 3 of 6
subregion 4 of 6
subregion 5 of 6
subregion 6 of 6
closecell: can't move C:\Users\yaraya\Documents\GIS
DataBase/meuse/PERMANENT/.tmp/1964.0
to cell file C:\Users\yaraya\Documents\GIS
DataBase/meuse/PERMANENT/fcell/ahn5m_interp
Cannot write quant rules: map ahn5m_interp is integer
unable to write quant file!
v.surf.bspline complete.
The white space in the path seems to trigger the problem.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1415>
