[GRASS-dev] Catching an issue from external binary using grass
Python Script
Glynn Clements
glynn at gclements.plus.com
Fri Jul 29 14:59:23 EDT 2011
Jenny Turner wrote:
> *Is it possible to get above text ("This application ..." in a variable?*
If it's being written to stdout or stderr, you can capture those by
replacing subprocess.call() with:
p = subprocess.Popen(<command>, stdout=subprocess.PIPE, stderr=subprocess.PIPE)
out, err = p.communicate()
out and err will be strings, containing the data written to stdout and
stderr respectively.
