[GRASS-dev] Re: ctypes problem with Vect_open_old
Maris Nartiss
maris.gis at gmail.com
Sat Jul 30 02:52:38 EDT 2011
Same here. Provided sample script runs just fine. Does it need some
special settings (Location, DB connection)?
Gentoo ~AMD64
gcc version 4.5.2 (Gentoo 4.5.2 p1.0, pie-0.4.5)
Python 2.7.2
Maris.
2011/7/29 Glynn Clements <glynn at gclements.plus.com>:
> Martin Landa wrote:
>> Unfortunately the sample script still fails
> I can't reproduce this. Running it under GDB might help, or it might
> not; memory corruption is like that.
