[GRASS-dev] compiling errors - grass65svn compiled in the
osgeo4w-stack
Helmut Kudrnovsky
hellik at web.de
Thu Jun 2 17:07:35 EDT 2011
hi,
I've compiled grass65svn in the osgeo4w-stack with r46521
there are following errors:
_____________________
syringia at NADA /c/osgeo4w/usr/src/grass6_devel
$ ./mswindows/osgeo4w/package.sh
GRASS GIS compilation log
Started compilation: Thu Jun 2 19:52:03 GMT 2011
Errors in:
/c/osgeo4w/usr/src/grass6_devel/lib/python
/c/osgeo4w/usr/src/grass6_devel/gui/icons
/c/osgeo4w/usr/src/grass6_devel/gui/images
/c/osgeo4w/usr/src/grass6_devel/gui/wxpython/scripts
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Thu Jun 2 20:48:10 GMT 2011
syringia at NADA /c/osgeo4w/usr/src/grass6_devel/lib/python
$ make
make: *** No rule to make target `|', needed by `/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/python/grass/script/core.py'. Stop.
syringia at NADA /c/osgeo4w/usr/src/grass6_devel/gui/icons
$ make
make: *** No rule to make target `/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/gui/icons/grass/channel-blue.gif', needed by `default'. Stop.
syringia at NADA /c/osgeo4w/usr/src/grass6_devel/gui/images
$ make
make: *** No rule to make target `/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/gui/images/grass_form.png', needed by `default'. Stop.
syringia at NADA /c/osgeo4w/usr/src/grass6_devel/gui/wxpython/scripts
$ make
make /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/scripts/d.rast3d.py /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/scripts/p.cmd.py
/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/scripts/p.db.py /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/scripts/p.mon.py
/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/scripts/p.rast.py /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/scripts/p.vect.py
c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/scripts/vkrige.py
make[1]: Entering directory `/c/osgeo4w/usr/src/grass6_devel/gui/wxpython/scripts'
make[1]: *** No rule to make target `/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc/wxpython/scripts/d.rast3d.py'. Stop.
make[1]: Leaving directory `/c/osgeo4w/usr/src/grass6_devel/gui/wxpython/scripts'
make: *** [install_scripts] Error 2
best regards
Helmut
___________________________________________________________
Schon gehört? WEB.DE hat einen genialen Phishing-Filter in die
Toolbar eingebaut! http://produkte.web.de/go/toolbar
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20110602/f637117b/smime.bin
