[GRASS-dev] compiling errors - grass65svn compiled in the
osgeo4w-stack
Martin Landa
landa.martin at gmail.com
Fri Jun 3 03:14:55 EDT 2011
2011/6/2 Glynn Clements <glynn at gclements.plus.com>:
> is an order-only dependency, which requires GNU make 3.81. In 6.x,
> this syntax is normally conditional upon "ifneq ($(BROKEN_MAKE),)". It
> appears that someone back-ported from 7.0 (where GNU make 3.81 is a
> requirement) without changing this.
lib/python/Makefile has been changed my me 10months ago [1]. I just
wonder why it didn't fail on Helmut's machine earlier.
Glynn: is it right just to remove "|" or it needs some special care?
Thanks, Martin
[1] http://trac.osgeo.org/grass/changeset/42916/grass/branches/develbranch_6/lib/python/Makefile
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
