[GRASS-dev] Weekly reports #1 wxNviz
Maris Nartiss maris.gis at gmail.com
Sat Jun 4 05:27:17 EDT 2011
Hello,
can You, please, explain a bit more about "3D mode can be used only in
one map display window"? You are not planning to rewrite OGSF, still
somebody else might do that someday and it would save time to know
some limitations.
Thanks,
Maris.
2011/6/3, Anna Kratochvílová <KratochAnna at seznam.cz>:
> Hi,
> 1) What do I have completed this week?
> Fixed bugs in lighting, preferences, drawing vectors on surfaces and others.
> I realized that 3D mode can be used only in one map display window due to
> ogsf library,
> so I make some changes to prevent user from using more windows in 3D mode
> (I'm not going to rewrite ogsf).
> I added more possibilities in wxNviz preferences, changed layout of certain
> GUI parts.
> New functionality: constant surfaces, look here feature.
> 2) What am I going to achieve for next week?
> I'm going to work on cutting planes.
> 3) Is there any blocking issue?
> No
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
