[GRASS-dev] Error compiling the latest grass7svn
Moritz Lennert
mlennert at club.worldonline.be
Wed Jun 8 04:56:58 EDT 2011
On 08/06/11 05:01, Pierre Roudier wrote:
> Hi,
> I just encountered the following error while compiling the last svn up
> of grass_trunk:
> In file /usr/local/src/grass7-svn/grass_trunk/dist.x86_64-unknown-linux-gnu/include/grass/gprojects.h,
> couldn't find ogr_srs_api.h
> I turned ogr_srs_api.h to gdal/ogr_srs_api.h and it did pass the error
> and compiled.
using --with-gdal=[path/to/gdal-config] as a configure option should do
the trick.
Moritz
