[GRASS-dev] [GRASS GIS] #1388: r3.univar gives bad results for cell
counts
trac at osgeo.org
Sun Jun 12 01:27:19 EDT 2011
#1388: r3.univar gives bad results for cell counts
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Raster | Version: svn-develbranch6
Keywords: r3.univar | Platform: Linux
Cpu: x86-32 |
`r3.univar` gives wrong results for cell counts.
tested in 6.5svn on debian oldstable&stable ia32&amd64.
2x2 test
cat << EOF > test_rast3d_2x2.asc
north: 2.0
south: 0.0
east: 2.0
west: 0.0
top: 2.0
bottom: 0.0
rows: 2
cols: 2
levels: 2
0 1
1 0
1 0
0 1
EOF
r3.in.ascii in=test_rast3d_2x2.asc out=test3d.2x2
g.region rast3d=test3d.2x2
r3.univar test3d.2x2
==> total null and non-null cells: 0
==> total null cells: -8
Of the non-null cells:
n: 8
minimum: 0
maximum: 0
range: 0
mean: 0.5
mean of absolute values: 0.5
standard deviation: 0.5
variance: 0.25
variation coefficient: 100 %
sum: 4
stats seem ok, cell counts at top of 0,-8 should be 8,0.
3x3 test
cat << EOF > test_rast3d_3x3.asc
north: 3.0
south: 0.0
east: 3.0
west: 0.0
top: 3.0
bottom: 0.0
rows: 3
cols: 3
levels: 3
0 0 1
0 1 0
1 0 0
1 0 0
0 1 0
0 0 1
0 1 0
0 1 0
0 1 0
EOF
r3.in.ascii in=test_rast3d_3x3.asc out=test3d.3x3
g.region rast3d=test3d.3x3
r3.univar test3d.3x3
==> total null cells: -27
n: 27
minimum: 0
maximum: 0
range: 0
mean: 0.333333
mean of absolute values: 0.333333
standard deviation: 0.471405
variance: 0.222222
variation coefficient: 141.421 %
sum: 9
same header text is wrong, but the rest of the stats (including n) are ok.
The `r3.info` values look ok.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1388>
