[GRASS-dev] Re: [GRASS GIS] #1388: r3.univar gives bad results for
cell counts
trac at osgeo.org
Tue Jun 14 04:51:41 EDT 2011
#1388: r3.univar gives bad results for cell counts
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Raster | Version: svn-develbranch6
Keywords: r3.univar | Platform: Linux
Cpu: x86-32 |
Comment(by hamish):
Replying to [comment:3 mmetz]:
> I have submitted some more (tested) fixes, particularly for zonal stats.
thanks, I'll give it a better look after I get back from sea.
> IMHO, it may be safer to have val_f and val_d as FCELL and
> DCELL because they are used in G3d_getValue().
my main concern is that I apparently went to the trouble of adding a
comment that they should be available for general use, so I'd like to
audit that we aren't breaking any assumptions based on that comment, and
no new casts are needed.
also I notice that r3.to.rast is giving me just min=max=0 2D maps from
seemingly good 3D floating point temperature data? (gr6.5; r3.null was run
to remove value=99.999 null cells, maybe that had something to do with
it?)
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1388#comment:4>
