[GRASS-dev] Principle G3D library question
Maris Nartiss
maris.gis at gmail.com
Tue Jun 21 07:13:26 EDT 2011
Hello,
It's not an backporting of header it's about GRASS6 being able to
distinguish GRASS7 format g3d files. I have not peaked into code if
there such feature exists. If not, it should be implemented to prevent
GRASS6 failures (or worse - data corruption) on GRASS7 files.
Maris.
2011/6/18 Soeren Gebbert <soerengebbert at googlemail.com>:
> I don't think it is necessary to backport the header changes to 6.x.
> The grass6 version works fine, maybe a manual update is meaningful?
> For backward compatibility a flag was added to r3.out.ascii which is
> IMHO not overkill. :)
