[GRASS-dev] Principle G3D library question
Markus Metz
markus.metz.giswork at googlemail.com
Tue Jun 21 08:42:41 EDT 2011
On Tue, Jun 21, 2011 at 1:58 PM, Maris Nartiss <maris.gis at gmail.com> wrote:
> I would suggest to change grass7 to something not GRASS release dependent.
See [0] and following lines for an example of file format versioning
independent of the release
[0] https://trac.osgeo.org/grass/browser/grass/trunk/include/vect/dig_defines.h#L151
Silently following the thread,
Markus M
> just my 0.02,
> Maris.
> 2011/6/21 Soeren Gebbert <soerengebbert at googlemail.com>:
>> Hi Maris,
>> the new rater3d ascii header looks like this now:
>> version: grass7
>> order: nsbt
>> north: 80.000000
>> south: 0.000000
>> east: 120.000000
>> west: 0.000000
>> top: 50.000000
>> bottom: 0.000000
>> rows: 8
>> cols: 12
>> levels: 5
>> The options "version" and "order" are introduced with my changes on
>> the g3d library in grass7. The manual page of the svn version of
>> r3.out.ascii in grass7 explains a bit more.
>> Best regards
>> Soeren
>> 2011/6/21 Maris Nartiss <maris.gis at gmail.com>:
>>> (Still haven't looked at code) - I hope GRASS7 files will have a
>>> version number in header to be future-proof.
>>> Maris.
>>>> Hi Maris,
>>>>> Hello,
>>>>> It's not an backporting of header it's about GRASS6 being able to
>>>>> distinguish GRASS7 format g3d files. I have not peaked into code if
>>>>> there such feature exists. If not, it should be implemented to prevent
>>>>> GRASS6 failures (or worse - data corruption) on GRASS7 files.
>>>> I see, good point!
>>>> The grass6 implementation checks for valid header:
>>>> static void readHeaderString(FILE * fp, char *valueString, double *value)
>>>> static char format[100];
>>>> /* to avoid buffer overflows we use snprintf */
>>>> G_snprintf(format, 100, "%s %%lf", valueString);
>>>> if (fscanf(fp, format, value) != 1) {
>>>> G_debug(0, "bad value for [%s]", valueString);
>>>> fatalError("readHeaderString: header value invalid");
>>>> while (fgetc(fp) != '\n') ;
>>>> I think this should prevent the import of new grass7 volume ascii
>>>> files in grass6. The grass6 import will break in when the new lines of
>>>> the grass7 header are parsed.
>>>> Best regards
>>>> Soeren
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
