[GRASS-dev] Re: [GRASS GIS] #1330: wxGUI: "UnicodeEncodeError: 'ascii' codec can't encode characters" in pl_PL.UTF-8
Tomas_IV brunclik at atlas.cz
Fri Jun 24 08:32:23 EDT 2011
Martin Landa wrote:
>> are you also changing opacity level at this point?
> or renaming the map layer (using non-ascii characters).
I did not change the opacity AFAIK, but yes, there somehow appeared the
(průhlednost 100%) note in the list of layers and that was the cause (in
english there is (opacity 100%)).
BTW the word "průhlednost" is wrong translation, there shoud be
"neprůhlednost".
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-GIS-1330-wxGUI-UnicodeEncodeError-ascii-codec-can-t-encode-characters-in-pl-PL-UTF-8-tp6189279p6511786.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
