[GRASS-dev] Re: [GRASS-SVN] r46717 -
grass/branches/releasebranch_6_4/scripts/v.build.all
Hamish
hamish_b at yahoo.com
Mon Jun 27 19:05:59 EDT 2011
MMetz:
> > CMD="v.build map=${VECT}@${MAPSET}"
> > - g.message "$CMD"
> > + g.message message="$CMD"
> > $CMD
> > done
MNeteler:
> ... is this a needed change?
> Most are without this parameter...
Needed in this case because the string contains a '=', which
confuses the parser.
Hamish
ps- those curly brackets do nothing..
