[GRASS-dev] [GRASS GIS] #1395: osgf generates error compiling on
	Mac OS X
    trac at osgeo.org
    Tue Jun 28 14:41:34 EDT 2011
#1395: osgf generates error compiling on Mac OS X
 Reporter:  cmbarton   |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  normal     |   Milestone:  7.0.0
Component:  Compiling  |     Version:  svn-trunk
 Keywords:  osgf nviz  |    Platform:  MacOSX
      Cpu:  OSX/Intel  |
 I just updated from the SVN and also installed the newest frameworks. osgf
 fails to compile with the following error. This (I think) also causes nviz
 to fail to compile too.
 cmb-mbp-3:grass70_dev cmbarton$ cd
 /Users/Shared/grass_dev/grass70_dev/lib/ogsf
 cmb-mbp-3:ogsf cmbarton$ make
 cc -dynamiclib -compatibility_version 7.0 -current_version 7.0
 -install_name
 /Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib/libgrass_ogsf.7.0.svn.dylib
 -o /Users/Shared/grass_dev/grass70_dev/dist.i386-apple-
 darwin10.8.0/lib/libgrass_ogsf.7.0.svn.dylib
 -L/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-darwin10.8.0/lib
 -arch i386 -arch x86_64     OBJ.i386-apple-darwin10.8.0/GK2.o OBJ.i386
 -apple-darwin10.8.0/GP2.o OBJ.i386-apple-darwin10.8.0/GS2.o OBJ.i386
 -apple-darwin10.8.0/GSX.o OBJ.i386-apple-darwin10.8.0/GS_util.o OBJ.i386
 -apple-darwin10.8.0/GV2.o OBJ.i386-apple-darwin10.8.0/GVL2.o OBJ.i386
 -apple-darwin10.8.0/Gp3.o OBJ.i386-apple-darwin10.8.0/Gs3.o OBJ.i386
 -apple-darwin10.8.0/Gv3.o OBJ.i386-apple-darwin10.8.0/Gvl3.o OBJ.i386
 -apple-darwin10.8.0/gk.o OBJ.i386-apple-darwin10.8.0/gp.o OBJ.i386-apple-
 darwin10.8.0/gpd.o OBJ.i386-apple-darwin10.8.0/gs.o OBJ.i386-apple-
 darwin10.8.0/gs_bm.o OBJ.i386-apple-darwin10.8.0/gs_norms.o OBJ.i386
 -apple-darwin10.8.0/gs_query.o OBJ.i386-apple-darwin10.8.0/gsd_cplane.o
 OBJ.i386-apple-darwin10.8.0/gsd_fonts.o OBJ.i386-apple-
 darwin10.8.0/gsd_fringe.o OBJ.i386-apple-darwin10.8.0/gsd_img_mpeg.o
 OBJ.i386-apple-darwin10.8.0/gsd_img_ppm.o OBJ.i386-apple-
 darwin10.8.0/gsd_img_tif.o OBJ.i386-apple-darwin10.8.0/gsd_label.o
 OBJ.i386-apple-darwin10.8.0/gsd_legend.o OBJ.i386-apple-
 darwin10.8.0/gsd_objs.o OBJ.i386-apple-darwin10.8.0/gsd_prim.o OBJ.i386
 -apple-darwin10.8.0/gsd_surf.o OBJ.i386-apple-darwin10.8.0/gsd_views.o
 OBJ.i386-apple-darwin10.8.0/gsd_wire.o OBJ.i386-apple-
 darwin10.8.0/gsdiff.o OBJ.i386-apple-darwin10.8.0/gsdrape.o OBJ.i386
 -apple-darwin10.8.0/gsds.o OBJ.i386-apple-darwin10.8.0/gsget.o OBJ.i386
 -apple-darwin10.8.0/gv.o OBJ.i386-apple-darwin10.8.0/gv_quick.o OBJ.i386
 -apple-darwin10.8.0/gvd.o OBJ.i386-apple-darwin10.8.0/gvl.o OBJ.i386
 -apple-darwin10.8.0/gvl_calc.o OBJ.i386-apple-darwin10.8.0/gvl_calc2.o
 OBJ.i386-apple-darwin10.8.0/gvl_file.o OBJ.i386-apple-darwin10.8.0/gvld.o
 OBJ.i386-apple-darwin10.8.0/trans.o  -lgrass_bitmap.7.0.svn
 -lgrass_g3d.7.0.svn -lgrass_vector.7.0.svn -lgrass_raster.7.0.svn
 -lgrass_gis.7.0.svn   -L/Library/Frameworks/UnixImageIO.framework/unix/lib
 -ltiff  -framework OpenGL -framework AGL -framework ApplicationServices
 Undefined symbols:
   "_db_get_value_int", referenced from:
       _Gp_load_sites_thematic in Gp3.o
   "_db_select_value", referenced from:
   "_db_start_driver_open_database", referenced from:
   "_db_get_value_string", referenced from:
 ld: symbol(s) not found
 collect2: ld returned 1 exit status
 Undefined symbols:
 lipo: can't open input file:
 /var/folders/AK/AKpYwDw1EoWI+fFF02nvRk+++TI/-Tmp-//ccAxZpeP.out (No such
 file or directory)
 make: *** [/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-
 darwin10.8.0/lib/libgrass_ogsf.7.0.svn.dylib] Error 1
Ticket URL: <http://trac.osgeo.org/grass/ticket/1395>
