[GRASS-dev] Re: [GRASS GIS] #508: hardcoded /dev/null
GRASS GIS trac at osgeo.org
Thu Mar 3 10:38:37 EST 2011
 Reporter:  hamish              |       Owner:  grass-dev@…
     Type:  defect              |      Status:  new
 Priority:  major               |   Milestone:  6.4.0
Component:  Default             |     Version:  6.4.0 RCs
 Keywords:  wingrass /dev/null  |    Platform:  MSWindows XP
      Cpu:  x86-32              |
Comment(by glynn):
 Replying to [comment:4 hamish]:
 > as in comment:2 I'm not sure how to fix r.out.mpeg.
 G_system("ppmtompeg 2>" G_DEV_NULL);
 A more significant issue is gee_wildfiles(), which does:
     sprintf(cmd, "cd %s; \\ls %s >> %s 2> /dev/null",
             path, wildarg, tfile);
 If you want a complete replacement, the 7.0 version of xganim uses
 G_spawn_ex() and g.mlist.
 > I'm not sure if xganim could be made to work on WinGrass or not, but
 it's better replaced by the wxGUI animator version. (?)
 The 6.x xganim requires Motif and an X server, which is probably more
 trouble than it's worth.  Also, on Windows and MacOSX you would need to
 either use Lesstif (which is still "beta" quality and barely maintained)
 or buy a commercial version of Motif; the OpenMotif licence is limited to
 open-source platforms.
Ticket URL: <http://trac.osgeo.org/grass/ticket/508#comment:5>
