[GRASS-dev] Re: [GRASS GIS] #1300: WxGUI measure tool gives wrong
results
trac at osgeo.org
Tue Mar 8 06:18:02 EST 2011
#1300: WxGUI measure tool gives wrong results
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: wxGUI | Version: svn-releasebranch64
Keywords: measure tool | Platform: MSWindows Vista
Cpu: Unspecified |
Changes (by hamish):
* keywords: => measure tool
Comment:
Ok, I can reproduce this on Linux using the latest 6.4.1svn, 6.5svn &
spearfish.
notice that it works in the y-direction but not the x-direction.
well, as long as the white bands are on the left-right, not top-bottom. if
you resize the map window so that the white out-of-region bands are on the
left,right sides, then the measure tool works along the x-asix but not the
y-axis.
so it seems to be using window size not region size, and the bigger the
out-of-region bands, the bigger the d.measure error.
go into preferences and tick the 'constrain' box and it starts to work
better.
also in 6.5svn I notice if I mouse wheel zoom out, the 10km barscale no
longer exactly matches the d.grid lines. (some mm out on the screen) maybe
a d.barscale bug, but I've only known that to be 1px out on the right end.
> (Did I sed that current measure tool mouse bindings suck?)
please suggest what would be better. (thoughts on comment:2 ?)
... also, I notice in 6.5svn all maps are missing from d.rast map name
GUI:
GSelect: invalid item: descriptor 'lower' requires a
'unicode' object but received a 'str'
Hamish
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1300#comment:4>
