[GRASS-dev] Re: [GRASS GIS] #1122: Command line hangs where dialog
boxes work
trac at osgeo.org
Wed Mar 9 17:34:04 EST 2011
#1122: Command line hangs where dialog boxes work
Reporter: JonBall | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Default | Version: 6.4.0 RCs
Keywords: wingrass | Platform: MSWindows Vista
Cpu: Unspecified |
Comment(by hellik):
Replying to [ticket:1122 JonBall]:
> When trying to use the command line to test the fix of Ticket #809
(http://trac.osgeo.org/grass/ticket/809#) , commands at the command line
all appear to return the error "Bad file descriptor: Files" error.
However, if you just type the command name without parameters you get a
dialog box. Using the dialog box to perform the exact same command
results in no error.
closing the ticket?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1122#comment:3>
