[GRASS-dev] [GRASS GIS] #1304: wx: map selection with LANG=C causes
error
trac at osgeo.org
Thu Mar 10 21:17:37 EST 2011
#1304: wx: map selection with LANG=C causes error
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: Linux
Cpu: x86-64 |
(moved here from #1300)
when LANG=C you get this error when you go to pick a map from the wxGUI
drop-down list (e.g. in d.rast):
GSelect: invalid item: descriptor 'lower' requires a
'unicode' object but received a 'str'
with LANG=en_NZ.UTF-8 it works ok.
tested with latest 6.5svn.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1304>
