[GRASS-dev] Re: [GRASS GIS] #1308: wingrass - dbf.exe-crash
trac at osgeo.org
Sun Mar 13 13:15:40 EDT 2011
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.1
Component: Default | Version: svn-releasebranch64
Keywords: wingrass, dbf.exe, d.vect | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:5 martinl]:
> Replying to [comment:4 martinl]:
> > Replying to [comment:1 hellik]:
> > > Replying to [ticket:1308 hellik]:
> > > > it seems the crash is nearby the v.db.connect- and db.describe-
steps.
> > > after finishing wingrass, in the windows task manager it seems there
are still some db.describe.exe-instances running.
> > it's strange that it crashes only sometimes, it's probably unrelated
but with r45652 I was not able to reproduce this bug. Can you test it?
> build available at
http://josef.fsv.cvut.cz/wingrass/grass64/WinGRASS-6.4.SVN-r45652-1-Setup.exe
it's very strange. tested in following way with the nc-sample-dataset
adding
always geology, firestations, lakes and geonamesNC in the same order:
self compiled r45652 in the osgeo4w-stack:
(1) starting wingrass in the osgeo4w-windows-shell(command line):
first run adding
-geology dbf.exe-crash
- firestations dbf.exe-crash
- lakes ok
- geonames dbf.exe-crash
exit the grass-session and starting a new second one, all vector are
loading normally
(2) starting wingrass in the osgeo4w-msys-shell:
-geology ok
- firestations ok
- lakes dbf.exe-crash
- geonames ok
loading normally
(3) testing
all vectors added with the d.vect without any dbf.exe-crash.
Helmut
p.s. no dbf.exe-crash with create a new vector by v.digit in all 3
approaches
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308#comment:6>
