[GRASS-dev] Re: [GRASS GIS] #1310: Browse button in WxPython GUIs
(for scripts) does not provide a correct file path for WinGRAS
trac at osgeo.org
Sat Mar 26 12:56:21 EDT 2011
#1310: Browse button in WxPython GUIs (for scripts) does not provide a correct
Reporter: katrineggert1980 | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.1
Component: wxGUI | Version: 6.4.1 RCs
Keywords: winGRASS | Platform: MSWindows XP
Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:1 hellik]:
> tested with WinGRASS-6.4.SVN-r45749-1-Setup.exe
> r.out.xyz input=elevation at PERMANENT output=C:\wd\exportgrass\routxyz.txt
> c:/Program Files/GRASS 6.4.SVN/scripts/r.out.xyz: line 61:
> C:wdexportgrassroutxyz.txt: Permission denied
Looking at the *script* r.out.xyz, we see that a redirection is used:
# if no output filename, output to stdout
if [ -z "$GIS_OPT_OUTPUT" ] || [ "$GIS_OPT_OUTPUT" = "-" ]; then
r.stats -1gn "$GIS_OPT_INPUT" fs="$GIS_OPT_FS"
else
r.stats -1gn "$GIS_OPT_INPUT" fs="$GIS_OPT_FS" > "$GIS_OPT_OUTPUT"
fi
I suspect that this is causing problems on Windows.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:3>
